PowerOx327
How do I manipulate column formulae in data tables by scripting?
I'm trying to add a formula to convert values in a selected column through scripting without having to add any new columns in the data table, is there a way to edit formulas for a column by scripting? For example I'm trying to set the height column in this data table to be halved when I run the script:
Open( "$SAMPLE_DATA/Big Class.jmp" );
Current Data Table() << Get Column Names;
height = height/2;
Re: How do I manipulate column formulae in data tables by scripting?
Your specified formula is recursive when used as a column formula.  A column formula will run whenever it detects a change in the column.
What you are suggesting can simply be done in open JSL.
height = height/2;
or
For( i = 1, i <= N Rows( current data table() ), i++,
	:height[i] = :height[i] / 2
or
dt:Height << set values( dt[0, 4] / 2 );
If the formula isn't recursive, one can set the column formula by using the Set Formula message
:height << set formula(:weight/2);
I strongly suggest that you take the time to read the Scripting Guide available in the JMP Documentation Library under the Help pull down menu
A data column formula is just a JSL expression that is evaluated row-wise. You can use the data column messages << Get Formula() and << Set Formula(). Use expression functions to access and modify the expressions as needed.
height = height/2;
or
or
