BookmarkSubscribe
lorikuo
Community Member
How do I import multiple files from excel and distinguish them?
I understand I can record a script to automate and import only the rows with data.
I also want to make two columns of the file name and time (which are in the excel file, but not in column format). Is there a way to do that from the JMP end without modifying my excel files? Otherwise, I was going to add two extra columns in my excel files pointing to the cells that have that data.
Help will be appreciated!
