BookmarkSubscribe
justin_blair
How do I hide function definitions
I'm trying to make a jsl file in JMP 10 that other users can include and use the functions defined.  I don't want them to see the innards of these functions.  I need them to be able to call function_a(param1,2,3) and get a result but not be able to call function_a and see Function({a,b,c} try(all of this needs to be hidden));.  Is there something I can do to make my functions act more like the reserved words of JMP ( a hover over tooltip but no definition of how the function works)?
pmroz
Re: How do I hide function definitions
If you encrypt your jsl file that contains your functions, users will no longer be able to see the innards.
Edit > Encrypt Script
pmroz
