Hi All,
I am plotting spectral signatures of marine macro-algae. I have 55 columns that I put into the x-axis, but the y-axis does not auto reflect the numbers that are contained in the x-axis columns. My x-axis columns are formatted as continuous numeric fixed decimal (2) in both datasheets. This is what it looks like when I plot it:
I found out how to do this once before so that it works as auto-populating the y-axis with a different datasheet, but similarly spectral signatures that have a distinct data layout, but have now spent about a day trying to figure out the answer and could not find it. This is what it should look like with the values on the y-axis auto-populating to the actual values reflected in my x-axis column. I do not want to transform my data for these graphs and want them to show the actual values in my columns.
I am using jmpPro 16.0.0 on with Windows (not a mac). I mostly use the user interface- have not scripted much.
Appreciate any help someone could provide.
