LimitedInfo
How do I do a Chi-Square test with duplicate rows of data?
I'm trying to do a Chi-Square test. I have multiple rows of data for individual restaurants. I only need one row per restaurant because the type of cuisine for each restaurant is constant between months. Should I reformat the data or is there a way to do the Chi-Square test with the data in the picture?
(I wouldn't have to worrry about this problem if I had the same number of months per restaurant, however I do not.)
Re: How do I do a Chi-Square test with duplicate rows of data?
This is a quick way with a summary table.
  1. Select Tables > Summary.
  2. Select Ticket, Cuisine, and Sig, then click Group.
  3. Click OK.
Now use the new summary table,
  1. Select Analyze > Fit Y by X
  2. Select Cuisine and click Y
  3. Select Sig and click X
  4. Click OK.
Your mosaic plot and contingency table should depict the conditional probabilities and the Chi square test should be at the bottom.
I test of what, in terms of the variables you show in the picture of the data table?
LimitedInfo
A test of whether there is a significant difference in the frequency of cuisine type between Sig of 0 restaurants and Sig of 1 restaurants.
  3. Click OK.
  4. Click OK.
