marjolein
How do I create a model with a defined profile as a factor?
Hi all,
I have a question regarding DoE design.
Normally, I use continuous factors with fixed values for 0, -1, +1, with the custom design DoE. However, I now have to create a model for a cell culture process (duration is multiple days), where one of the input factors has a profile at the lower range (the other factors will be fixed values for 0, -1, +1). Can someone explain to me how I can design this model?
further more, what would be preferred, from a statistical point of view:
1) keep upper range fixed and centerpoint fixed, so only profile for lower range
or
2) have same shape profile for upper range and centerpoint as used for -1
I have plotted scenenario 1 and 2 in the attached file as I cannot add the pictures in this message.
any help is very welcome, I very much look forward to your response/ideas
kind regards,
Marjolein
Andrea_
Re: How do I create a model with a defined profile as a factor?
Hi Marjolein,
yes, the categorical factor wouldn't follow a profile, but it doesn't have to. Just create a categorical factor with three levels:
Factor NameRoleValues
XCategoricalL1 = profile 1L2 = profile 2L3 = profile 3
The profiles don't have to be the same, each can follow an unique time-program. The "mid-level" (profile 2) doesn't have to be the "center-point" as you showed in your Word-file in figure 2. You can take the profiles as in figure 1.
Regards,
Andrea
Andrea_
Hello Marjolein,
as far as I know, there is no preferred profile from the "statistical point of view". You have a categoric factor which is the profile. The question is: Which version does make more sense for the cell culture process and the purpose of your experiment?
Regards,
Andrea
marjolein
Hi Andrea,
Thanks for your reply!
Can you explain a bit further how you would apply categorical variables to make the profile in time? I assumed that the levels for the categorical factors will be same value throughout process time, so its then not creating a profile over time.
kind regards, Marjolein
Andrea_
Hi Marjolein,
Regards,
Andrea
Article Labels
