BookmarkSubscribe
seanschubert
Community Trekker
How do I create a 2D Map with lines from geo-point 1 to geo-point 2?
I'd like to create a map of the US with lines connecting some of the cities. This is for a Supply Chain application so ideally the width of the lines would be proportional to sales shipped between each of those sets of points. Once I have the lines in place, I can add the US as a background map. Which graph function should I use?
ballardw
Community Trekker
Re: How do I create a 2D Map with lines from geo-point 1 to geo-point 2?
There is one example here: http://support.sas.com/kb/24/897.html
Calculate the line thickness (size) using your sales data.
seanschubert
Community Trekker
Are there any ways to do it in JMP? I don't have access to SAS.
ms
Super User ms
The Line() function draws a line within e.g. a graph and can be part of a graphics script. To add many lines iteratively it's safest to work with a string representation of the graphics script and parse it in each iteration. The JSL example below may give you some ideas.
// Example table with sales between four cities and their coordinates.
dt = New Table( "LinesBetweenCities.jmp",
  Add Rows( 10 ),
  New Column( "City",
  Character,
  Set Values(
  {"Cleveland, Ohio", "Cleveland, Ohio", "Cleveland, Ohio", "Cleveland, Ohio", "Des Moines, Iowa", "Des Moines, Iowa", "Des Moines, Iowa",
  "Los Angeles, Calif.", "Los Angeles, Calif.", "Montgomery, Ala."}
  New Column( "N", Numeric, Format( "Best", 12 ), Set Values( [41.467, 41.467, 41.467, 41.467, 41.583, 41.583, 41.583, 34.05, 34.05, 32.35] ) ),
  New Column( "W",
  Numeric,
  Set Values( [-81.617, -81.617, -81.617, -81.617, -93.617, -93.617, -93.617, -118.25, -118.25, -86.3] )
  New Column( "Sales", Numeric, Continuous, Format( "Best", 12 ), Formula( Round( Random Uniform(), 2 ) ) ),
  New Column( "With",
  Character,
  Nominal,
  Set Values(
  {"Cleveland, Ohio", "Des Moines, Iowa", "Los Angeles, Calif.", "Montgomery, Ala.", "Des Moines, Iowa", "Los Angeles, Calif.",
  "Montgomery, Ala.", "Los Angeles, Calif.", "Montgomery, Ala.", "Montgomery, Ala."}
  Set Row States( [8, 0, 0, 0, 8, 0, 0, 8, 0, 8] ),
  Set Label Columns( :City )
gb = Graph Builder(
  Variables( X( :W ), Y( :N ) ),
  Elements( Points( X, Y, Legend( 1 ) ) ),
  Dispatch(
  "Graph Builder",
  FrameBox,
  {Background Map( Boundaries( "US States" ) ), Marker Size( 6 ), Grid Line Order( 2 ), Reference Line Order( 3 ),
  DispatchSeg(
  ShapeSeg( 1 ),
  {Line Color( {204, 204, 204} ), Fill Color( "None" ), Missing shape fill( 2147483647 ), Missing value fill( -14540253 )}
fb = Report( gb )[FrameBox( 1 )];
// String representation of script that draws a line
line_string =
"fb << add graphics script( 3, Pen Color( {.3, .5, .7} );
  Pen Size( ^round( 10 * :Sales, 0)^);
  Line( {^:W^, ^:N^}, {^:W[coord]^, ^:N[coord]^})
// Add graphics scripts that draw lines between each pair of cities. Pen Size depends on Sales.
For( i = 1, i <= N Row( dt ), i++,
  coord = (dt << getrows where( :with[i] == :City ))[1]; //get coordinates of the city in the With column
  Eval( Parse( Eval Insert( line_string ) ) ); // evaluate the variables within line_str and parse the text into working jsl
