lala
How do I convert this file to table form using JSL?
  • Column names can be used with other names.Thanks!
var hq_str_CON_OP_10002283="6,0.5050,0.5050,0.5055,1,1805,14.96,2.5000,0.4393,0.4535,0.7332,0.1454,0.5115,1,0.5106,1,0.5100,1,0.5071,1,0.5055,1,0.5050,6,0.5035,2,0.5033,1,0.5029,1,0.4930,1,2020-03-05 15:00:00,0,E 01,EBS,510050,50ETF��3�2500,14.32,0.5160,0.4531,443,2161832.00,M,0.4393,C,2020-03-25,20,2,0.504,0.001";
var hq_str_CON_OP_10002284="1,0.4542,0.4596,0.4602,1,1233,18.15,2.5500,0.3888,0.4067,0.6829,0.0951,0.4698,2,0.4696,1,0.4679,1,0.4613,1,0.4602,1,0.4542,1,0.4531,1,0.4434,1,0.4428,1,0.4416,1,2020-03-05 14:46:33,0,E 01,EBS,510050,50ETF��3�2550,16.74,0.4674,0.4023,270,1172730.00,M,0.3890,C,2020-03-25,20,2,0.454,0.0056";
var hq_str_CON_OP_10001937="1,0.4464,0.4460,0.4495,2,6268,16.24,2.5580,0.3837,0.3980,0.6776,0.0898,0.4538,22,0.4534,1,0.4522,1,0.4512,10,0.4495,2,0.4464,1,0.4460,1,0.4457,1,0.4451,1,0.4402,1,2020-03-05 14:55:52,0,E 01,EBS,510050,50ETF��3�2558A,16.91,0.4599,0.3950,812,3602321.08,A,0.3837,C,2020-03-25,20,2,0.446,0";
var hq_str_CON_OP_10002285="1,0.4051,0.4060,0.4093,1,1824,19.06,2.6000,0.3410,0.3553,0.6349,0.0471,0.4180,6,0.4169,1,0.4120,1,0.4105,1,0.4093,1,0.4051,1,0.4035,1,0.4000,1,0.3950,1,0.3949,1,2020-03-05 14:54:46,0,E 01,EBS,510050,50ETF��3�2600,18.33,0.4159,0.3534,1134,4421563.00,M,0.3410,C,2020-03-25,20,2,0.404,0.002";
var hq_str_CON_OP_10001933="1,0.3983,0.3972,0.4036,1,3308,19.49,2.6070,0.3324,0.3476,0.6263,0.0385,0.4110,1,0.4094,1,0.4051,1,0.4045,10,0.4036,1,0.3983,1,0.3966,1,0.3923,10,0.3882,1,0.3865,1,2020-03-05 14:54:14,0,E 01,EBS,510050,50ETF��3�2607A,18.08,0.4073,0.3472,506,1990874.79,A,0.3324,C,2020-03-25,20,2,0.397,0.0002";
var hq_str_CON_OP_10002286="1,0.3560,0.3539,0.3595,5,4136,21.41,2.6500,0.2915,0.3063,0.5854,0.0001,0.3626,1,0.3614,1,0.3598,5,0.3596,1,0.3595,5,0.3560,1,0.3544,1,0.3526,10,0.3470,1,0.3455,1,2020-03-05 14:56:38,0,E 01,EBS,510050,50ETF��3�2650,22.02,0.3680,0.3038,2248,7596257.00,M,0.2915,C,2020-03-25,20,2,0.354,-0.0001";
var hq_str_CON_OP_10001929="1,0.3491,0.3518,0.3545,1,2471,24.05,2.6570,0.2836,0.2965,0.5775,0.0001,0.3637,1,0.3590,1,0.3575,1,0.3556,11,0.3545,1,0.3491,1,0.3475,1,0.3432,10,0.3402,1,0.3389,1,2020-03-05 14:48:16,0,E 01,EBS,510050,50ETF��3�2657A,23.66,0.3631,0.2960,490,1677430.59,A,0.2836,C,2020-03-25,20,2,0.347,0.0048";
var hq_str_CON_OP_10002065="1,0.3070,0.3062,0.3090,1,14271,24.52,2.7000,0.2459,0.2610,0.5398,0.0001,0.3155,1,0.3133,1,0.3130,1,0.3126,1,0.3090,1,0.3070,1,0.3060,12,0.3059,1,0.3058,1,0.3053,2,2020-03-05 14:55:05,0,E 01,EBS,510050,50ETF��3�2700,25.95,0.3200,0.2562,4845,14034069.00,M,0.2459,C,2020-03-25,20,2,0.304,0.0022";
var hq_str_CON_OP_10001909="1,0.3011,0.3000,0.3064,1,2453,26.10,2.7060,0.2379,0.2522,0.5318,0.0001,0.3138,2,0.3136,1,0.3098,1,0.3073,1,0.3064,1,0.3011,1,0.2996,1,0.2976,10,0.2964,1,0.2932,1,2020-03-05 14:56:53,0,E 01,EBS,510050,50ETF��3�2706A,26.90,0.3139,0.2499,1076,3044899.84,A,0.2379,C,2020-03-25,20,2,0.298,0.002";
var hq_str_CON_OP_10002066="6,0.2600,0.2600,0.2623,10,13716,30.65,2.7500,0.1990,0.2112,0.4929,0.0001,0.2693,1,0.2656,1,0.2646,1,0.2638,1,0.2623,10,0.2600,6,0.2585,21,0.2575,1,0.2573,1,0.2571,1,2020-03-05 15:00:00,0,E 01,EBS,510050,50ETF��3�2750,31.86,0.2720,0.2086,12034,29269407.00,M,0.1990,C,2020-03-25,20,2,0.254,0.006";
lala
Re: How do I convert this file to table form using JSL?
I don't know how to upload the attachment?
Here is a script that will input your data file, and do the conversions to the formatted file as you show in your entry. I am not exactly sure this is what you want, but it should be a starting point for the answer to your question.
dt = Open(
	"<Path to your file?",
	Import Settings(
		End Of Line( CRLF, CR, LF ),
		End Of Field( Comma, Other( "\!"" ), CSV( 0 ) ),
		Strip Quotes( 1 ),
		Use Regional Settings( 0 ),
		Scan Whole File( 1 ),
		CompressNumericColumns( 0 ),
		CompressAllowListCheck( 0 ),
		Labels( 0 ),
		Column Names Start( 1 ),
		Data Starts( 1 ),
		Lines To Read( "All" ),
		Year Rule( "20xx" )
// Convert the first column to just the last set of numbers
For Each Row( :Column 1 = Word( -1, :Column 1, "=_" ) );
// Rename the column names
alphabet = "ABCDEFGHIJKLMNOPQRSTUVWXYZ";
For( i = 1, i <= N Cols( dt ), i++,
	firstCharacterPosition = Floor( i / 26 );
	If( firstCharacterPosition == 0,
		firstCharacter = "",
		firstCharacter = Substr( alphabet, firstCharacterPosition, 1 )
	secondCharacterPosition = Mod( i, 26 );
	If( secondCharacterPosition == 0,
		secondCharacterPosition = 26
	secondCharacter = Substr( alphabet, secondCharacterPosition, 1 );
	Column( i ) << set name( firstCharacter || secondCharacter );
