How do I concatenate all open data tables
Joe
Jan 5, 2017
Hi all,
This is my first time posting here, I have a script where I automatically open "n" tabs from excel into tables (where "n" is any number from 4 to 25) and then concatenate them. As the number of tabs changes is there any way in which I can just concatenate all currently open data tables rather than having to input every table name?
Thanks,
Joe
markbailey
Jun 23, 2011
Solution
I should have mentioned that you should test this option interactively first. That is, select Open and then select your Excel workbook. You should then enter the Excel Import Wizard where you will find the option (check box) for concatenation.
This way will verify that what you want to do is possible and, if so, you can copy the Source table script to begin your own script.
markbailey
Jun 23, 2011
You can use the optional argument to the Open() function to have the tables concatenated for you. See the Scripting Guide for details (Help > Books > Scripting Guide).
markbailey
Jun 23, 2011
Solution
Joe
Jan 5, 2017
Thank you very much! This is perfect!
