JC7
JC7
How do I combine these codes?
Hi there,
I would like to combine these codes so that they run from the "Formulation Change Review (new)" and closes the new data table/tabulate tab only leaving the graph.
Any help much appreciated!
(Data Table( "Formulation Change Review (new)" ) <<
Tabulate(
	Add Table(
		Column Table( Grouping Columns( :Lab RFT ), Statistics( Row % ) ),
		Row Table( Grouping Columns( :Grade ) )
)) << Make Into Data Table
Graph Builder(
	Size( 1896, 951 ),
	Show Control Panel( 0 ),
	Show Legend( 0 ),
	Variables(
		X(
			:Grade,
			Order By( :Name( "Row %(Y)" ), Ascending, Order Statistic( "Mean" ) )
		Y( :Name( "Row %(Y)" ) ),
		Overlay( :Grade )
	Elements( Bar( X, Y, Legend( 6 ), Label( "Label by Value" ) ) ),
		Dispatch( {}, "graph title", TextEditBox, {Set Text( "RFT % per grade" )} ),
		Dispatch( {}, "Y title", TextEditBox, {Set Text( "RFT%" )} )
Craige_Hales
Re: How do I combine these codes?
untested, but split it up into smaller blocks like this:
dt1 = Data Table( "Formulation Change Review (new)" );
tab = (dt1 << Tabulate(
	Add Table(
dt2 = tab << Make Into Data Table;
gb = dt2 << Graph Builder(
	Size( 1896, 951 ),
	Show Legend( 0 ),
	Variables(
		X(
			:Grade,
		Overlay( :Grade )
		Dispatch( {}, "Y title", TextEditBox, {Set Text( "RFT%" )} );
tab<<closewindow;
close(dt2,nosave);
// gb is the handle to the graphbuilder report
edit: There appear to be missing ) at the end of the graph builder section. Make sure you grab all of the JSL from the save-to-script-window when you paste it together.
edit 2: just before the close(dt2,nosave) you might want to
gb << journal;
gb<<closewindow;
because the graph builder report needs the table open but the journal is self contained. The journal'd graph is not connected to the data and can't do row selection.
Craige
