Djtjhin
How do I automate random sampling generation from different distribution types?
Let's say I have a table with 5 rows & 2 columns. The first column is for distribution types (e.g. Normal, Lognormal, Weibull, etc) and the second column is for the respective parameters. I'd like to make a for loop which will create a new data table for each of the 5 rows, where in that new data table, a new column will be added with a random sampling function based on the parameters of the row.
e.g. row 1 --> Normal, (0.1,0.02); Create a new data table with a column that has a formula of
randomnormal(0.1,0.02)
My current challenge is that different distribution types require varying number of parameters. Appreciate some insights on how I should approach this.
Re: How do I automate random sampling generation from different distribution types?
Here is a simple example of how to do what you requested
dt = New Table( "Sample",
	Add Rows( 5 ),
	New Column( "Types",
		Character,
		Set Values(
			{"Normal", "Lognormal", "Weibull", "Uniform", "Johnson Su"}
		Set Display Width( 79 )
	New Column( "Parameters",
		Character,
		Set Values(
			{"(0.1,0.02)", "(0.2,.005)", "(0.3,0.005)", "(0.1,0.5)",
			"(0.5, 1, 1, 1)"}
		Set Display Width( 101 )
For( i = 1, i <= N Rows( dt ), i++,
	Eval(
		Substitute(
				Expr(
					New Table( dt:Types[i],
						add rows( 20 ),
						New Column( "Random " || dt:Types[i],
							set each value( __formula__ )
			Expr( __formula__ ),
				Parse( "Random " || dt:Types[i] || dt:Parameters[i] )
Please take the time to fully understand how the script works, and if you do not understand it, please respond back so the Community can provide you with the additional information you may need.
Thierry_S
A couple thoughts:
1) If possible, I would split the parameters across columns to make the scripting of the formula easier
2) I would use the MATCH formula to look for the name of the distribution and specifically call the Random function for the corresponding distribution
Match( :Distribution,
	"Normal", Random Normal( :Parameter 1, :Parameter 2 ),
	"LogNormal", Random Lognormal( :Parameter 1, :Parameter 2 ),
Thierry R. Sornasse
Djtjhin
Thanks Thierry, any suggestions if I want to limit the number of columns for the parameters ?
Another concern that I have is, I believe the Match() formula is case sensitive. I can try to control this by putting a List Check on the column. Are there other ways to control / manage that ?
Thierry_S
For the case sensitive issue, here is the fix:
Match( Uppercase( :Distribution ),
	"NORMAL", Random Normal( :Parameter 1, :Parameter 2 ),
	"LOGNORMAL", Random Lognormal( :Parameter 1, :Parameter 2 ),
About limiting the number of columns, I will get back to you because it is a little bit trickier.
Best,
TS
Thierry R. Sornasse
	Add Rows( 5 ),
		Character,
		Set Values(
		Character,
		Set Values(
			"(0.5, 1, 1, 1)"}
	Eval(
		Substitute(
				Expr(
						add rows( 20 ),
Djtjhin
It works Jim! Thanks
