clarencelew
How do I add a filter column as a AND criteria
The syntax for Add Filter dictates that the new columns must be in the OR criteria.
Is there some way I can add rules in an iterative way?
dtf<<Add Filter(columns(column <,col>), <Where(clause)>)
Add one or more filter columns in a new OR group.
11 REPLIES 11
pmroz
Re: How do I add a filter column as a AND criteria
To figure this out:
Create a graph using Big Class
Add a local data filter with 2 variables (e.g. age and sex) using the AND button
Select criteria from both variables in the filter
Click the red triangle and select Script > Copy Script
Here's an example that shows the necessary syntax:
dt = open("$sample_data/Big Class.jmp");
// AND
Graph Builder(
     Show Control Panel( 0 ),
     Variables( X( :weight ), Y( :height ) ),
     Elements(
           Points( X, Y, Legend( 1 ), Jitter( 1 ) ),
           Smoother( X, Y, Legend( 3 ) )
     Local Data Filter(
           Location( {935, 334} ),
           Mode( Select( 0 ), Show( 1 ), Include( 1 ) ),
           Add Filter(
                columns( :age, :sex ),
                Where( :age == {12, 13, 14} ),
                Where( :sex == "M" )
clarencelew
Hi PMroz,
Appreciate the response. But what I'm trying to achieve here is to add a filter to the current one after I've done some other crunching..
gb = Graph Builder(
   //Where( :sex == "M" )
//do something else here...
gb << Add Filter(
  columns( :sex ),
chungwei
Staff (Retired)
Is this what you have in mind ?
// AND
gb = Graph Builder(
     Elements(
df = gb << Local Data Filter(
           Add Filter(
                columns( :age ),
df << Add Filter(
                columns( :sex ),
                Where( :sex == "M" ),
jimloughlin
are you missing a semi-colon (;) between the two df statements?
Jim Loughlin
Loughlin Consulting
clarencelew
Hi Chung Wei,
That would only add the criteria as an OR condition not AND...
chungwei
Staff (Retired)
sorry. I did not ask the question correctly.
I meant to ask if you would like to send separate messages to the data filter, instead of the way PMRoz showed.
newbie_alex
I have the same issue. is there a way to add an AND filter instead of an OR filter (which was already shown by staff member chungwei)?
ian_jmp
Level X
Using Chung-Wei's example:
dt = Open( "$sample_data/Big Class.jmp" );
// AND
gb = Graph Builder(
	Elements( Points( X, Y, Legend( 1 ), Jitter( 1 ) ), Smoother( X, Y, Legend( 3 ) ) ),
Wait( 3 );
// OR
	Add Filter( columns( :age ) ),
	Add Filter( columns( :sex ) )
Wait( 3 );
// AND
df << removeLocalDataFilter;
	Add Filter( columns( :age, :sex ) )
newbie_alex
Thank you for the quick reply. That will work.
Is there also a way to define the list of filter columns in a List variable and forward this to the filter (the name of my filter columns are dynamic)?
e.g.
filter_vars = {"age","sex"};
and somehow use filter_vars as an input for the data filter (instead of columns(:age,:sex))
