Elby
How do I Graph All Months with No Data for Some Months?
Version - jmp 12
Intent - Graph (X-Y, Dist etc) qty per month, including months with no qty
Data example - Qty Sold
Item            Yr-Mo         Qty
  AA          2018-01          5
  BB          2018-01          2
  CC          2018-01          5
  AA          2018-02          6
  CC          2018-02          4
  AA          2018-04          3
  BB          2018-04          7
The question is - How do I show 2018-01 2018-02 2018-03 etc on the x-axis even if there was no qty for every month?  If this is answered prior, please let me know where as I did not find an answer.
Thank you
Re: How do I Graph All Months with No Data for Some Months?
If you enter in the data using a valid JMP Date column, and specify that m/y is the format to use....see attached data table, the graph will include the missing months on the axismonthyear.GIF
Elby
Thank you, that seemed to work.
For reference, is it possible to use Yr/Mo as a date?
If you look at the Date formats that are available, you will see there is an m/y format. There is also a y/m/d format. There does not seem to be a y/m format for output.
Dan Obermiller
