lala
Level IX
How can use JSL to automatically add code to "Event Handler" in "Properties" of a specified column?
Big Class.jmp
Thanks!
Function( {thisTable, thisColumn, iRow},
 n1rows = thisTable << Get Rows Where( :n1 == thisTable:thisColumn[iRow] );
 n2rows = thisTable << Get Rows Where( :n2 == thisTable:thisColumn[iRow] );
 thisTable << Select Columns( {thisColumn, :n1, :n2} ) << Clear Cell Colors;
 thisColumn << Color Cells( {3, {iRow}} );
 :n1 << Color Cells( {3, n1rows} );
 :n2 << Color Cells( {3, n2rows} );
mmarchandTSI
Level V
Re: How can use JSL to automatically add code to "Event Handler" in "Properties" of a specified column?
Use the <<Add Column Properties message:
:name << Add Column Properties(
	Set Property(
		"Event Handler",
		Event Handler(
			Click(JSL Quote(Function( {thisTable, thisColumn, iRow},
mmarchandTSI
Level V
	Set Property(
		"Event Handler",
		Event Handler(
lala
Level IX
If I want to implement in the "event handler" of this column property that clicking on a cell in the name column automatically opens a web image with the text of that name with JMP Do I want to encode this Function() content?
Assuming that the site is:
https://community.jmp.com/KATIE.png
Thanks!
