lala
Level IX
How can this JSL be used to create this graphic?
This is the code I wrote for the AI to view images, but I failed to add any text successfully.
Thanks Experts!
// === 1. Data & Parameters ===
SolarTerms = {
    "夏至", "小暑", "大暑", "立秋", "处暑", "白露",
    "秋分", "寒露", "霜降", "立冬", "小雪", "大雪",
    "冬至", "小寒", "大寒", "立春", "雨水", "惊蛰",
    "春分", "清明", "谷雨", "立夏", "小满", "芒种"
OuterRadius = 10;
InnerRadius = OuterRadius / 2;
TermCount = N Items( SolarTerms );
SummerSolsticeX = 0; SummerSolsticeY = OuterRadius;
WinterSolsticeX = 0; WinterSolsticeY = -OuterRadius;
OuterX = J( TermCount, 1, . );
OuterY = J( TermCount, 1, . );
InnerX = J( TermCount, 1, . );
InnerY = J( TermCount, 1, . );
AngleList = J( TermCount, 1, . );
FontName = If( Host Is( "Mac" ), "Helvetica", "Arial" );
// === 2. Geometry ===
For( i = 1, i <= TermCount, i++,
    Angle = Pi() / 2 - (i - 1) * (2 * Pi() / 24);
    AngleList[i] = Angle;
    OuterX[i] = OuterRadius * Cos( Angle );
    OuterY[i] = OuterRadius * Sin( Angle );
    If( i <= 13,
        Progress = (i - 1) / 12;
        SmallAngle = Pi() / 2 - (Pi() * Progress);
        CX = 0; CY = InnerRadius;
        Progress = (i - 13) / 12;
        SmallAngle = Pi() / 2 + (Pi() * Progress);
        CX = 0; CY = -InnerRadius;
    InnerX[i] = CX + InnerRadius * Cos( SmallAngle );
    InnerY[i] = CY + InnerRadius * Sin( SmallAngle );
// === 3. Window ===
nw = New Window( "Twenty-Four Solar Terms · Yin Yang Cycle",
    gb = Graph Box(
        Frame Size( 800, 800 ),
        X Scale( -16, 16 ),
        Y Scale( -16, 16 ),
        Fill Color( "Black" );
        Rect( -20, 20, 20, -20, 1 );
        Pen Color( {240, 230, 140} );
        Pen Size( 2 );
        Transparency( 0.9 );
        Circle( {0, 0}, OuterRadius );
            ix = InnerX[i]; iy = InnerY[i];
            ox = OuterX[i]; oy = OuterY[i];
            If( i > 1 & i < 13,
                Transparency( 0.4 ); Pen Size( 1 );
                Line( {SummerSolsticeX, SummerSolsticeY}, {ix, iy} );
                Transparency( 0.15 );
                Line( {ix, iy}, {ox, oy} );
            If( i > 13,
                Line( {WinterSolsticeX, WinterSolsticeY}, {ix, iy} );
            If( i == 1,
                Transparency( 0.6 ); Pen Size( 2 );
                Line( {0, 0}, {0, OuterRadius} );
            If( i == 13,
                Line( {0, 0}, {0, -OuterRadius} );
            Pen Color( "Black" );
            Fill Color( {255, 215, 0} );
            Marker Size( 5 );
            Marker( 21, {OuterX[i], OuterY[i]} );
            Pen Color( {218, 165, 32} );
            Fill Color( {255, 255, 224} );
            Marker Size( 6 );
            Marker( 21, {InnerX[i], InnerY[i]} );
        Pen Color( "White" );
        Fill Color( {255, 250, 205} );
        Marker Size( 8 );
        Marker( 21, {0, 0} );
        LabelOffset = 1.8;
            Name = SolarTerms[i];
            A = AngleList[i];
            tx = (OuterRadius + LabelOffset) * Cos( A );
            ty = (OuterRadius + LabelOffset) * Sin( A );
            IsSolstice = ( Name == "夏至" | Name == "冬至" );
            TxtColor = If( IsSolstice, {255, 69, 0}, {224, 224, 224} );
            TxtSize = If( IsSolstice, 14, 11 );
            TxtWeight = If( IsSolstice, "bold", "plain" );
            Deg = A * 180 / Pi() - 90;
            Transparency( 1 );
            Fill Color( TxtColor );
            Text Font( FontName, TxtSize, TxtWeight );
            Text( Center Justified, {tx, ty}, Rotate( Deg ), Name );
        Text Font( FontName, 20, "bold" );
        Fill Color( "White" );
        Text( Center Justified, {0, 14.5}, "Twenty-Four Solar Terms · Yin Yang Cycle" );
gb << Show X Axis( 0 );
gb << Show Y Axis( 0 );
8 REPLIES 8
lala
Level IX
回复: How can this JSL be used to create this graphic?
python
Re: How can this JSL be used to create this graphic?
You have to set text color correctly (Text Color()) and you are using incorrect syntax for the angle of the text. Angle is determined with Text Font (check Scripting Index / JMP Help for the correct syntax and how to use it)
lala
Level IX
Thank jthi !
Could you help me keep making corrections?Thank you very much for your continued JSL reference.
lala
Level IX
I just want to achieve the effect of the original picture as much as possible.
Thanks Experts!
XanGregg
Check out the Scripting Index example for Text Font(). It does something similar that might be useful to your case.
lala
Level IX
I know this
I made this picture.
lala
Level IX
The rotation of the characters still hasn't been resolved
2026-01-06_16-52-55.pngThanks Experts!
mmarchandFSLR
Could just do this.
Deg = -(A * 180 / Pi() - 90);
