UersK
How can replace the following with a newline with a regular substitution in JMP software's JSL
t1=Regex(txt,"],[","\!n",globalreplace);//??
Re: How can replace the following with a newline with a regular substitution in JMP software's JSL
You need to escape [ and ] in regex (you could also use Substitute/Substitute Into)
txt = "a],[b";
t1 = Regex(txt, "\!],\!\[", "\!n", GLOBALREPLACE);
t2 = Substitute(txt, "],[", "\!N");
show(t1, t2);
https://www.jmp.com/support/help/en/17.0/index.shtml#page/jmp/jsl-syntax-rules.shtml
https://www.jmp.com/support/help/en/17.0/index.shtml#page/jmp/escaped-characters-in-regular-expressi...
txt = "a],[b";
show(t1, t2);
