BookmarkSubscribeRSS Feed
deny_hanan
Community Member
May 28, 2014
How can i split data
Shalom All
I have column data in this shape 677->661. I want to split it in tow columns, 1st clomn to be 677 and 2nd column to be 661,
677->661
714->714
711->697
673->673
658->684
711->725
694->714
705->725
707->722
696->703
685->698
709->711
672->659
712->690
715->715
how can i do it?
many thnaks
Deny Hanan
stan_koprowski
Community Manager
Aug 8, 2012
Re: How can i split data
There are a several different approaches to solving your problem.
One approach is to create two new columns.  With each new column use a column formula with the Word function and then change to a numeric value as follows.
Assuming your first column is called ID then the formula would be implemented as follows:
  • Num( Word( 1, :ID, "->" ) )
I have attached a data table with the column split into two new columns.
Alternatively, you could use the text-to-columns add-in.
Cheers,
Stan
