Theresa
How can i enlarge the default size of picture?
*If i think the default picture size is small and i want to enlarge it, what should i do ?
Bivariate( Y( :weight ), X( :height ) );
*The script i use to control the size is below, but the pic has no change after i add size(1000, 800), Why it now work?
Bivariate(
	Size( 1000, 800 ),
	Y( :weight ),
	X( :height )
Re: How can i enlarge the default size of picture?
You can change the size of all graphic window's defaults in JMP Preferences
     File==>Preferences==>Graphs
If you want to change just the scatterplot window in the Bivariate Plot you need to change the Frame size.
names default to here(1);
dt=open("$SAMPLE_DATA/big class.jmp");
biv=Bivariate( Y( :height ), X( :weight ) );
report(biv)[FrameBox(1)] << frame size(400,400);
See the Scripting Index for examples
     Help=>Scripting Index
Theresa
Thank you!
