BookmarkSubscribe
GoodMan
How can i close the stepwise window after run the model with JSL
Dear All,
Here i perform a Stepwise regression analysis and run my new model,then close the Fit Model dialog window.
The problem is still a fitness stepwise window is open. See the attached file. How can i add additional code to open this window and just keep the final report window open.
Thank you in advance
dt = Open( "$SAMPLE_DATA/Fitness.jmp" );
fit = dt << Fit Model(
Y( :Oxy ),
Effects( :Weight, :Runtime, :RunPulse, :RstPulse, :MaxPulse
Personality( Stepwise ),
Run Model( Prob to Enter( 0.2 ),
Direction( Mixed ),
Prob to Leave( 0.2 ) )
fit << Finish;
sm = fit << Make Model;
sm << Run Model;
Model Dialog[1] << Close Window;
