lwx228
Level VIII
How can add another column of text to a graph?
For example, use "Big Class.jmp".
A text column has been added as follows.
And make a graph, the need to graph the new column text in the graph display.
dt << New Column( "row", formula( Row() ) );
dt << run formulas;
Column( "row" ) << deleteFormula;
dt << Add Multiple Columns( "A", 2, Character, "Nominal" );
Column( dt, N Col( dt ) - 1 ) << set name( "max" );
Column( dt, N Col( dt ) ) << set name( "min" );
Column( "max" ) << Formula(
	If( height == Max( height[Index( Row() - 5, Row() + 5 )] ),
		name
dt << run formulas;
Column( "max" ) << deleteFormula;
Column( "min" ) << Formula(
	If( height == Min( height[Index( Row() - 5, Row() + 5 )] ),
		name
dt << run formulas;Column( "min" ) << deleteFormula;
c1 = Graph Builder(
	Size( 528, 456 ),
	Show Control Panel( 0 ),
	Variables( X( :row ), Y( :height ) ),
	Elements( Line( X, Y, Legend( 5 ) ) )
Thanks Experts!
Re: How can add another column of text to a graph?
I think this is what you want.  It creates the graph with only the Max column showing the labels, and then adds the Min column and the new labels show up.
dt:name << set labelled( 0 ); // Remove the default label
// Create the new row column
dt << run formulas;
// Add the first label column
dt << New Column( "max", character,
	Formula(
			name
dt << run formulas;
Column( "max" ) << set labelled( 1 );
dt << select where( :max != "" );
dt << Label;
dt << clear select;
// Run the graph
c1 = Graph Builder(
	Size( 528, 456 ),
	Elements( Line( X, Y, Legend( 5 ) ), Points( X, Y, Legend( 6 ) ) )
Report( c1 )[framebox( 1 )] << Marker Size( 0 );
// Wait added to allow initial labeling before adding new labeling
Wait( 5 );
// Add new label column
dt << New Column( "min", character,
	Formula(
			name
dt << run formulas;
Column( "min" ) << set labelled( 1 );
dt << select labeled;
dt << select where( :min != "", current selection( "extend" ) );
dt << Label;
dt << clear select;
By setting the RowState color to red for the rows where there are Max values, the displayed labels for those rows will be red.  I have added some code to the current script to handle the coloring.
dt << run formulas;
	Formula(
			name
dt << run formulas;
selectedRows = dt << get selected rows;
for(i=1,i<=NRows(selectedRows),i++,
	rowstate( selectedRows[i] ) = Color State ("red")
dt<<select where(:max !="");
dt << Label;
dt << clear select;
// Run the graph
c1 = Graph Builder(
	Size( 528, 456 ),
Wait( 5 );
	Formula(
			name
dt << run formulas;
dt << Label;
dt << clear select;
9 REPLIES 9
lwx228
Level VIII
Re: How can I add another column of text to a graph?
I failed to find a solution through the graphic code of "Big Class Families".
Graph Builder(Size(535,455),
Variables(X(:row),Y(:height)),Elements(Line(X,Y,Legend(5))),
SendToReport(Dispatch({},"Graph Builder",FrameBox,
{Marker Size(2),{
Add Pin Annotation(Seg(Marker Seg(1)),Index(9),Index Row(9),UniqueID(1180683047),Origin({64.8386487250506,97.865127215503}),Offset({-239,8}),Tag Line)
This discussion might help:
How to add value label to points?
dt << run formulas;
	Formula(
			name
dt << run formulas;
dt << Label;
dt << clear select;
// Run the graph
c1 = Graph Builder(
	Size( 528, 456 ),
Wait( 5 );
	Formula(
			name
dt << run formulas;
dt << Label;
dt << clear select;
lwx228
Level VIII
Thank Jim!
lwx228
Level VIII
How to use JSL to implement just will:the font for the "MAX" column is set to red.
Thanks Experts!
dt << run formulas;
	Formula(
			name
dt << run formulas;
dt << Label;
dt << clear select;
// Run the graph
c1 = Graph Builder(
	Size( 528, 456 ),
Wait( 5 );
	Formula(
			name
dt << run formulas;
dt << Label;
dt << clear select;
lala
Level IX
How can I modify the interval markers to use different colors?
Big Class.jmp uses this script to plot, "B" lists the height values of different ages by the number of rows to start and end.
The "B" column data that needs to be marked with the value of this B column as the interval, but requires the number of rows at the end of the age, is marked in red.
Thank Jim!
dt << Sort( By( age ), Order( Ascending ), replace table );
ca = "B";
r = N Row( dt );
New Column( ca );
Column( ca ) << Formula( If( Row() == r | Row() == 1 | age != Lag( age, 1 ) | age != Lag( age, -1 ), height ) );
dt << run formulas;
Column( ca ) << deleteFormula;
p1 = dt << Graph Builder(
	Variables( X( :weight ), Y( :height ), Group X( :age ), Color( :sex ), Interval( :B ) ),
	Elements( Bar( X, Y, Legend( 7 ), Response Axis( "X" ) ) )
By default, in JMP 17, the error bars take on the color specified by the "Color" variable.  In previous versions, the color was only determined by the color setting in the Customize Graph window.  However, only one color can be used.  Therefore, if you set the Error Bar color to Red, both the error bars for M and F would be red.
lala
Level IX
OK、Thank Jim!
