rleeper
Community Trekker
How can I use a variable in a chart legend?
I am trying to automatically include the number of pass / fail in my chart legend.
I tried:
f=N Items(Fail);
p=N Items(Pass);
//The assignment of f and p works, the values are in the variables.
PassFailChart = Graph Builder(
Variables(
  X( :Diff_Forward_Neg_3 ),
  Y( :Diff_Forward_Pos_3 ),
  Overlay( :Filter )
Elements( Points( X, Y, Legend( 3 ), Jitter( 1 ) ) ),
  Dispatch(
   "Graph Builder",
   OutlineBox,
   {Set Title(
    "Measurements Passing the 1e-10A @3V filter in Last 90 Days"
  Dispatch(
   "Diff_Forward_Neg_3",
   ScaleBox,
   {Scale( "Log" ), Min( 10 ), Max( 100000000000000 ), Inc( 1 ),
   Minor Ticks( 1 )}
  Dispatch(
   "Diff_Forward_Pos_3",
   ScaleBox,
   Minor Ticks( 1 )}
  Dispatch(
   "400",
   ScaleBox,
   {Legend Model(
    3,
    Level Name( 0, "Fail -" || f ),
    Level Name( 1, "Pass -" || p),
    Base( 0, 0, 0 ),
    Base( 1, 0, 0 ),
    Properties( 0, {Line Color( 3 )} ),
    Properties( 1, {Line Color( 5 )} )
  Dispatch(
   "400",
   LegendBox,
   {Set Title( "Current Filter Pass / Fail" )}
I also tried :
Level Name( 0, "Fail -" || f || "" ),
    Level Name( 1, "Pass -" || p || ""),
Neither worked.  Is this even possible?
ms
Super User ms
Re: How can I use a variable in a chart legend?
Not sure if it is possible. In any case f and p should be converted to strings before concat: "Fail -" || char(f).
An alternative approach is to set Value Labels for the Overlay column before plotting.
Script example:
// List with all levels
levels = Associative Array( :sex ) << get keys;
// Make list of value-label "assignments"
vl = Repeat(
    i = 0;
    {i++ ; Eval Expr(
        Expr( levels[i] ) = Expr( levels[i] || "-" || Char( Col Sum( :sex == levels[i] ) ), )
    N Items( levels )
// Set property
:sex << Value Labels( vl );
// make graph with overlay
Graph Builder( Variables( X( :age ), Y( :height ), Overlay( :sex ) ), Elements( Bar( X, Y, ) ) );
ms
Super User ms
Script example:
vl = Repeat(
    i = 0;
    {i++ ; Eval Expr(
    N Items( levels )
// Set property
rleeper
Community Trekker
MS,
You got it right first try.  I needed the Char function.  Chart looks amazing and now updates as the data changes, thank you!
   Level Name( 0, "Fail -" || Char(f) ),
    Level Name( 1, "Pass -" || Char(p)),
