News
On June 1, we’re asking you to select a content label when starting a new topic in the Discussions area. Read more to find out why.
CAPEGA
How can I use a dynamic column name?
How can I use a dynamic column name like this
 dt_tansposed = dt << Split(
Split By( :description ),
Split( Column Name(Value)), //??? Split(:VALUE) or Split(:AVG) works
Group( :Time ),
Remaining Columns( Drop All ),
Sort by Column Property
Thank you!
Re: How can I use a dynamic column name?
Try using Column(Value), instead of Column Name (Value).  See below:
dt=Open("$SAMPLE_DATA/Big Class.jmp");
Splitcolname="height";
dt << Split(
	Split By( :age ),
	Split( Column(Splitcolname) ),
	Group( :sex ),
dt << Split(
	Split By( :age ),
	Group( :sex ),
