brenner_sharp_y
How can I use JSL to save the results of screening into a table?
I am trying to automate the fitting of Neural network response surfaces, and I would like to perform a screening of my factors before I submit the factor list to be fitted with a Neural Network.
However, I can't figure out how to use JSL to save the screening results into a table. If I can do this, I can filter this table and load a column containing the factors into a local text variable list. Then I can submit this list to the JMP Neural Network module.
My problem is that there doesn't seem to be any way to save the table from a screening analysis.
ian_jmp
Re: How can I use JSL to save the results of screening into a table?
NamesDefaultToHere(1);
// Example table
dt = Open("$SAMPLE_DATA/Design Experiment/Plackett-Burman.jmp");
// Screening Platform
scr = dt << Screening(
Y( :Percent Reacted ),
X( :Feed Rate, :Catalyst, :Stir Rate, :Temperature, :Concentration )
// Save table from Screening Report
dt2 = Report(scr)[TableBox(1)] << makeDataTable;
dt2 << setName("Contrasts from "||(dt << getName));
ian_jmp
// Example table
