BookmarkSubscribeRSS Feed
gustavjung
How can I simulate trial execution model for virtual DoE?
Could you please help me with this problem?
I want to create a computer emulator for a learning purpose. It will emulate a binary outcome and use several Yes/No factors as an input (lets say A B C).
The output will be the % of successes.
The output when all factors are at "-" is 5% of successes.
When
A at "+"   5.5%  (0.5% gain)
B at "+"   6.5%  (1.5% gain)
C at "+"   5%  (0% gain)
A and B at "+" (AB interaction)   7.5% (2.5% gain)
So I want to implement it in a software as a trial execution model with the list of random trials and outputs(depending on levels of factors A-B-C).
Example of software behavior:
Order of trial    ABC     Output
1st trial           + + +    Fail
2nd trial          + - +     Fail
3rd trial           + -  -     Success
10000 trial       + -  -     Fail
I want it to look realistic so that not all the time the combination of A+ B- C- will result to "Success" because the process is not physical, it is a human response.
What is the general steps of constructing such an algorithm?
Can it be done in JMP?
In addition I am considering such tools as Excel, R, simulation software like Anylogic, Promodel is needed.
Big thanks!
Learning DOE
Re: How can I simulate trial execution model for virtual DoE?
This could probably be done more elegantly, but a quick "brute force approach" would be to enter the random formulas into a JMP data table. I made the A, B, and C columns a random integer column between 0 and 1 (I chose 0 instead of -1 for ease). Then for the Result column, I just entered a string of "If" conditions with the various probabilities from a binomial distribution with the appropriate probability of success. Fairly simple in this case since there are only 8 possible combinations of A, B, and C. For a larger problem I would try to be more elegant. The number of rows in your table will be the number of random trials you wish to have. For this simple case I just had 10 rows.
New Table( "Untitled",
  Add Rows( 10 ),
  New Column( "A", Numeric, "Nominal", Format( "Best", 12 ),
              Formula( Random Integer( 0, 1 ) ) ),
  New Column( "B", Numeric, "Nominal", Format( "Best", 12 ),
  New Column( "C", Numeric, "Nominal", Format( "Best", 12 ),
  New Column( "Success?", Numeric, "Nominal", Format( "Best", 12 ),
              Formula(
             If(
             :A == 0 & :B == 0 & :C == 0, Random Binomial( 1, 0.05 ),
             :A == 0 & :B == 0 & :C == 1, Random Binomial( 1, 0.05 ),
             :A == 0 & :B == 1 & :C == 0, Random Binomial( 1, 0.065 ),
             :A == 0 & :B == 1 & :C == 1, Random Binomial( 1, 0.065 ),
             :A == 1 & :B == 0 & :C == 0, Random Binomial( 1, 0.055 ),
             :A == 1 & :B == 0 & :C == 1, Random Binomial( 1, 0.055 ),
             :A == 1 & :B == 1 & :C == 0, Random Binomial( 1, 0.075 ),
             :A == 1 & :B == 1 & :C == 1, Random Binomial( 1, 0.075 ),
             Random Binomial( 1, 0.05 ) ) ) ) )
Dan Obermiller
7 REPLIES 7
  Add Rows( 10 ),
              Formula(
             If(
Dan Obermiller
gustavjung
Thank you very very much for this script! That is what I was seaching for.
Could you tell me please the reason why when I generated 10000 rows the Nominal Logistic regression doesnt show that A and AB are significant effects?
Learning DOE
Of course every simulation is different, but you are looking for very small effect sizes. With 10,000 trials, you will have approximately 5000 trials with A at 1, and 5000 trials with A at 0. Of those 5000 at 0, you expect a 5% "success" rate which is about 250 observations. With 5000 at 1, you expect 5.5% success rate, which is about 275 observations. Only a 25 observation difference out of the 10,000 total. That's a small difference. Add the random noise to this and you can see that the difference might actually be even smaller.
Categorical data typically requires larger sample sizes. That coupled with looking for very small effects leads to non-significance. Stated in more statistical terms, you have very low power to detect your desired effect sizes.
Dan Obermiller
gustavjung
Many thanks for clarification!
I've done calculation of minimal sample size so it could detect the difference of 0,5 %. However, sometimes the analysis of the simulated results doesn't detect AB interaction as significant with 64000 trials.
Have I done the calculations right?
Learning DOE
You are fitting models that are more complex than this sample size calculator was intended to do. There are extra degrees of freedom being used to estimate other terms.
I would suggest you go back to the formulas for each of the 8 different scenarios (combinations of A, B, and C) to make sure that you are using the proper probabilities. You had only provided four of the eight situations so I made some assumptions about the other four cases. You may wish to check those to make sure everything is as you expected it to be. I am guessing you are expecting the interaction effect to be a 2.5% gain, but the interaction term is NOT a 2.5% gain. You only get a 2.5% gain when both A and B are positive as you indicated. The interaction also includes what happens for the other 3 combinations of A and B.
As an example: A and B both positive: probability is 7.5%
                         A and B both zero: probability is 5%.  So when they are "the same sign" gives an average probability of 6.25%
     A zero, B positive: probability is 6.5%
     A positive, B zero: probability is 5.5% for an average probability of 6%.
Therefore, the interaction effect is actually 0.25% which is really small (and pretty close to your A*B interaction estimate in your analysis).
Dan Obermiller
gustavjung
Big thanks for all your help with simulation!
Could you help me please with modifying this script or suggesting a new approach for this task?
Now I want to simulate a definitive screening design. There are 18 factors.
Effect sizes:
Factor% of Successes
A1,31%
B1,42%
D1,58%
E1,64%
F1,46%
H1,39%
K1,34%
M1,37%
DE1,67%
FK1,54%
When all factors at low "0" level success rate is 1.2%.
Here is the exact design that I want to simulate:
X1X2X3X4X5X6X7X8X9X10X11X12X13X14X15X16X17X18
010100011000101101
100111010010010111
001011011010001100
011000101101101000
101001001011100111
110010010111001110
000011000101101101
000010110110100011
110111001110100100
010001011011010001
000000000000000000
101001011100111010
101110011101001001
010110100011000101
001000110001011011
110011101001001011
001101000110001011
111100111010010010
000101101101000110
000000000000000000
010110110100011000
001101101000110001
011010001100010110
111001110100100101
100100101110011101
111111111111111111
100101110011101001
101011100111010010
110100100101110011
110010111001110100
001100010110110100
011011010001100010
101110100100101110
111101001001011100
Learning DOE
gustavjung
Sorry, maybe I should create a new topic.
However, is it possible to accomplish my goal by using Simulate Response script that is built in JMP?
Learning DOE
