BookmarkSubscribeRSS Feed
DQR
Nov 18, 2016
How can I send a TableBox() to PowerPoint with an associated title?
I can create a chart in the Graph Builder and then send a copy of that chart, together with its title, to PowerPoint within a JSL script by doing essentially this:
   gb = Graph Builder( etc etc );
   gbb = report(gb)[GraphBuilderBox(1)];
   gbb << save presentation("MyFile.pptx")
This sends the title of the chart to the title bar of a PowerPoint slide, and puts the chart itself underneath it - which is exactly what I want. I can see from the tree structure of GraphBuilderBox(1) that the title itself is actually located in a TextEditBox within about five nested display boxes - so presumably when GraphBuilderBox(1) is sent to PowerPoint, the "<< save presentation()" property allows PowerPoint to recognise that it is supposed to be interpreted as the title of the slide.
I now want to do essentially the same thing with a TableBox (which obviously wasn't created within the Graph Builder), and an arbitrary title that I want to assign to that TableBox. What is the structure of display boxes that I need to assemble to make this work?
Many thanks for any suggestions
ian_jmp
Jun 23, 2011
Solution
Re: How can I send a TableBox() to PowerPoint with an associated title?
Something like:
New Window( "Example",
    ob = Outline Box( "Table",
                Table Box(
                        String Col Box( "names", {"x", "y", "z"} ),
                        Number Col Box( "values", {11, 22, 33} ),
                       Plot Col Box( "values", {11, 22, 33} )
ob << save presentation("$DESKTOP/MyFile.pptx");
ian_jmp
Jun 23, 2011
Solution
Something like:
                Table Box(
DQR
Nov 18, 2016
Ha!  It's as simple as that - and I infer that I could replace that TableBox by any other structure I wanted to export, with the title of the slide being taken from the title of the OutlineBox.  So in a nutshell, just put it in an OutlineBox and title it accordingly.
Many thanks again, Ian!
