BookmarkSubscribe
wilkap
Community Trekker
How can I script the Fit Model platform to use the model script in a data table?
When you use the "Fit Model" menu selection under "Analyze" it uses the "model" script in the table to run the analysis.  How can I do this through scripting? For example, the model script in a table has the Y's, the effects, and the personality information required by "Fit Model."  I just need to know how to get these to work together.  Thank you.
mjoner
Community Trekker
Re: How can I script the Fit Model platform to use the model script in a data table?
You could try something like
Current Data Table() << Run Script("Model");
You might also need to do something like this -- if you need to get the model to actually run:
modelscript = Current Data Table() << Get Property("Model");
Insert Into(modelscript,Expr(Run));
Eval(modelscript);
mjoner
Community Trekker
Eval(modelscript);
wilkap
Community Trekker
This worked perfectly!  Thank you.
