BookmarkSubscribeRSS Feed
How can I save the "Stepwise History" into a data table using JSL
frits_quadt
Feb 18, 2016
I am trying to save the "Stepwise History" results from the "Fit model" platform into a data table using the
following script:
obj = Fit Model( Y( :Y ), Effects( :X1, :X2, :X3, :X4, :X5, :X6, :X7, :X8, :X9, :X10, :X11, :X12, :X13, :X14 ), Personality( "Stepwise" ), Run( Stopping Rule( "P-value Threshold" ), Prob to Enter( 0.2 ), Direction( "Mixed" ) ) ); obj << go;
r = obj << Report; dt = r[Table Box( 4 )] << Make into Data Table; Close(dt,Save("Testsave.JMP"));
The reult is a data table with the column names from the stepwise history, but with zero rows. So the information I need for the rest of my analysis is not in the table, while the report does show the history.
Does anyone have an idea to get this working?
Jun 22, 2012
Solution
You need to "Finish" the platform.  See script below:
origdt = Open( "$SAMPLE_DATA\semiconductor capability.jmp" );
obj = origdt << Fit Model(
	Y( :NPN1 ),
	Effects(
		:PNP1,
		:PNP2,
		:NPN2,
		:PNP3,
		:IVP1,
		:PNP4,
		:NPN3,
		:IVP2,
		:NPN4,
		:SIT1,
		:INM1,
		:INM2,
		:VPM1,
		:VPM2,
		:VPM3,
		:PMS1,
		:SNM1,
		:SPM1,
		:NPN5
obj << go;
obj << finish;
r = obj << Report;
dt = r["Step History"][Table Box( 1 )] << Make into Data Table;
Close( dt, Save( "Testsave.JMP" ) );
Jun 22, 2012
Solution
	Y( :NPN1 ),
	Effects(
		:PNP1,
		:PNP2,
		:NPN2,
		:PNP3,
		:IVP1,
		:PNP4,
		:NPN3,
		:IVP2,
		:NPN4,
		:SIT1,
		:INM1,
		:INM2,
		:VPM1,
		:VPM2,
		:VPM3,
		:PMS1,
		:SNM1,
		:SPM1,
		:NPN5
obj << go;
obj << finish;
r = obj << Report;
frits_quadt
Feb 18, 2016
Thank, I have already applied this and it works great,
