BookmarkSubscribeRSS Feed
How can I open only JMP files from a folder?
Hi Guys,
I am trying to save the names of all JMP files only into a list. I am trying something like below and it is not working:
listofJMPfiles is showing me all the files in the folder and not just JMP files. Is there any other way to do this?
Thanks.
mpb
Super User mpb
Re: How can I open only JMP files from a folder?
Same idea as your March question: http://support.sas.com/forums/message.jspa?messageID=33161#33161
Use the Ends With function instead of Starts With and remove filenames ending with the string which when upper cased is ".JMP".
I don't think there is a direct way to specify a file mask.
