BookmarkSubscribeRSS Feed
maribliss
Community Member
Nov 12, 2017
How can I move the x-axis on top of graph?
Hi, I'm trying to create a trace element concentration profile and need to have the x-axis (concentrations) at the top of the graph so that it can show how the concentration varies down-core .. Is there any way to do this?
ian_jmp
Jun 23, 2011
Re: How can I move the x-axis on top of graph?
If you run this script:
NamesDefaultToHere(1);
gb = dt << Graph Builder(
	Size( 528, 452 ),
	Variables( X( :weight ), Y( :height ) ),
	Elements( Points( X, Y, Legend( 6 ) ) ),
		Dispatch(
			"weight",
			ScaleBox,
			{Label Row(
				{Inside Ticks( 1 ), Show Major Grid( 1 ), Show Minor Grid( 1 ),
				Show Minor Labels( 1 )}
it produces:
(which you could make interactively, of course).
I then did 'Edit > Journal' to make a Journal file, then used the 'fat plus' tool to move elements around to make:
David_Burnham
Jul 13, 2011
Finally we discover a reason why we might want to select the axes in isolation from the graph :)
-Dave
