BookmarkSubscribeRSS Feed
How can I monitor process capability of multiple processes in a single screen or interactive report?
thenson
Community Member
Oct 30, 2012
We are a small company and I'm somewhat of a novice to JMP10 and am wanting some input or direction about how to monitor multiple processes on an ongoing basis. For example, if I have several different files or even spreadsheets with ongoing data, can I use JMP to connect to these data sources and create a management screen that will show an overview of how the processes are doing from a process control/capability perspective?
I've seen the term "dashboard" used in software that is designed to monitor multiple processes, but can something like this be done in JMP?
If so, I would love to see an actual sample of a similar application using JMP.
thanks,
thenson
