How can I make 5>-1>=0.999 return the expected result of 0?
Sep 6, 2023 05:23 AM(2252 views)
Please ask a question: I was under the impression that JSL can be used to compare consecutively, for example: 5>-1>=0.999, but the running result is 1, what is the reason? Do I have to write 5>-1 & -1>=0.999?
