BookmarkSubscribeRSS Feed
How can I judge value cell and modify it in JMP script?
Sorry! I’m a beginner in JSL.
I want to judge value of cell it will be deleted if it was not I want in cell.
Such as : if( {column[4] ,row[5]} =1 , column[4],row[5]->will be deleted) ,
How can I do?
pmroz
Re: How can I judge value cell and modify it in JMP script?
Chris,
If you want to test a cell value and then delete the cell value you can use something like this:
dt = current data table();
for (i = 1, i <= nrows(dt), i++,  // Loop over all column 4 values
    if (column(4)[i] == 1,
    // then
        column(4)[i] = .; // Numeric "null"
wiebepo
There are a number of ways to use criteria to delete rows. Here is a solution to the example shown:
::data_table=currentdatatable();
If(column(::data_table,4)[5]==1, ::data_table<<deleterows(5));
pmroz
Chris,
    // then
Thank you for your answer
You help me solve a knotty trouble.
gbu
gbu
Maybe something like this :
RowsToDelete = dt << Get Rows Where(:COLUMN_NAME = 4);
dt << Delete Rows(RowsToDelete);
Regards,
Guillaume
