BookmarkSubscribe
uday_guntupalli
Community Trekker
How can I find rows that have elements of my list ?
Hello All,
            I am wondering as to what is the best way to achieve this. I have a list of elements and a data table . I want to figure out the easiest way to select all rows in one column that have the elements of my list (inclusive of duplicates) . The code that I am using is :
for(i = 1, i<= N Items(CheckList),i++,
dt_List << Select Where(Pat Match(:ColName,CheckList[i]) == 1);
dt_List << Label ;
dt_List << Select Labelled Rows ;
where CheckList - is my list for e.g. CheckList = {1,2,3,4} ;
          :ColName - is the name of my column
           dt_List - is the name of the data table I am working with
         The above piece of code only selects only the rows for the last item of my list . However , the label shows up on the appropriate rows.
Best
Uday
Best
Uday
ian_jmp
Re: How can I find rows that have elements of my list ?
I'm a little nervous over the use of the word 'best' above, but here's one way:
NamesDefaultToHere(1);
// Make a list of unique ages, removing a couple of items at random
mylist = AssociativeArray(Column(dt, "age") << getValues) << getKeys;
RemoveFrom(myList, RandomInteger(1, NItems(myList)), 1);
Print(myList);
// Select the requisite rows
r = dt << getRowsWhere(Contains(myList, :age));
dt << selectRows(r);
ian_jmp
Print(myList);
uday_guntupalli
Community Trekker
Ian@JMP​ :
             Thanks for your response. I have found the following helpful too :
MyList = {"611","680","323","410"};
dt << select where(contains(MyList, char(:ColName)));
Alternatively :
dt << Select Where(Pat Match(:ColName,CheckList[i]) == 1, current selection("extend"));
These were suggestions I received from other resources and I hope it will help the next guy .
Best
Uday
Best
Uday
