CAPEGA
How can I execute several statements after an if
How can I execute several statements after an if liike this:
If( selected == "Option1",
Request = "6";
Table = "Table1"; // ignored? needs to be fixed
Value = "Value1"; // ignored? needs to be fixed
Thanks!
Re: How can I execute several statements after an if
The commented lines should not be ignored when the IF statement is run.  Please try out the following script and note the result in the Log.  You can experiment by changing x from 5 to 4 in line 2.  Does this help?
x=5;
If(x==5,
	Print("This works");
	Print("This also works");
	Print("This works too");
	Print("This shouldn't print");
	Print("Or this");
	Print("This neither");
x=5;
If(x==5,
	Print("Or this");
