BookmarkSubscribe
yannntima
How can I do a table correspond to Analysis Distribution
Hi all,
The problem I met, is that i made an analysis with "Distribution"  and it was OK (see the picture below) :12557_Capture23.PNG
But the fact is that I tried to do the same on a tableau format but I can not divide per "Voies" (see the pictures below) :
Note : the only greatness I loocking for are ==> Mean, Max, Min Sigma (écart-type).
If someone had a solution it's will be great.
Ps : you can find in attach the JMP file
Thank;
Yann N
Re: How can I do a table correspond to Analysis Distribution
Are you looking for something like this?
To get this I changed the modeling type of Voies to be nominal. The Tabulate (or tableau) command will not automatically group continuous variables like this because there could be way too many groups. It will need to be Ordinal or Nominal modeling type.
Dan Obermiller
yannntima
Thanks to you,
It is completely wht I loocking for. I did not think about change the modeling type of Voice.
Yann N
