BookmarkSubscribeRSS Feed
jtwoodcock
Sep 15, 2015
How can I display only upper or lower confidence intervals in the Degradation Data Analysis module?
I'm currently using the Degradation Data Analysis module to trend stability data.  In certain cases I am only interested in displaying the lower confidence interval to reduce the amount of clutter in the graph.  I have seen a description of displaying confidence intervals here: Options for Continuous Variables.  However, I do not see the option of Confidence Interval > Other when using the Degradation Data Analysis package.  I am using JMP 11.2.0, 64-bit version on Windows 7.  Any help would be greatly appreciated.
girlme80_yahoo_
Dec 7, 2015
Re: How can I display only upper or lower confidence intervals in the Degradation Data Analysis module?
Go to the topmost triangle in your result page (usually called "Degradation Data Analysis") and select Graph Options. Un-check any option that you do not want to see in your graph.
