ajayhinduja25
How can I cluster travel behavior data using JMP?
Hi everyone,
I'm Ajay Hinduja, a passionate traveler based in Geneva, Switzerland. Alongside my love for exploring new destinations, I’m also deeply interested in staying up to date with the latest technology and data analysis tools—especially those that help make sense of real-world patterns in travel behavior.
I’m currently working with a dataset related to traveler preferences and behaviors, and I’d like to understand how to perform clustering analysis using JMP.
Regards
Ajay Hinduja Geneva, Switzerland
P_Bartell
Level VIII
Re: How can I cluster travel behavior data using JMP?
If your goal is to just understand JMP's capabilities in the multivariate/clustering space I suggest starting with the JMP documentation: Multivariate Analysis in JMP
If your goal is to address a specific analytic question wrt to a practical problem and your data...then please provide more details wrt to the problem and the data...clustering may or may not be an appropriate method for the problem or the data. But there might be some other methods/capabilities in JMP that can work for you?
