How can I calculate the intersection point of two functions in JMP?
I am graphing two functions in JMP using the YFunction command in JSL. I would like to calculate the point where they intersect. How should I do this either manually or in JSL?
Thanks for the help!
10 REPLIES 10
mpb
mpb
Re: How can I calculate the intersection point of two functions in JMP?
1. Graph > Profiler
2. Y --> Y, Prediction Formula
3. Click on red triangle button next to "Prediction Profiler"
4. Click on Desirability Functions
5. Alt-Click the upper right hand box
6. Click the Maximize Button and change to Match Target
7. Change the Values to 20, 0, and -20 (for High, Middle, and Low)
8. Click Ok
9. Click on the red triangle button next to "Prediction Profiler"
10. Click on Maximize Desirability
At various stages you may want to fiddle with the axes to more clearly display what is going on.
