ducduy9104
How Formula works in New Column Function
Hi everyone,
dt = Open( "$SAMPLE_DATA\Big Class.jmp" );
New Column("Sum",
"Numeric",
"Continuous",
Set Formula(If(Row() == 1, :Height, Lag(:Sum,1) + :Height))
The code above creates Sum column with calculated the accumulative sum. I am new to JSL so could someone explain me how the Formula command works. Is it scan one by one row in the column so that we can write :Height instead of constructing a For-loop with [i] which indicates the position of the current rows.
And have any other ways to do this cumsum?
Tks everybody and have a good day!
Re: How Formula works in New Column Function
Formulas do loop through each row, applying the given formula to the values from each row.  You can read the documentation on formulas in the "Using JMP" document
     Help==>Books==>Using JMP
An alternative version of your formula could be expressed as
dt<<new column("sum",formula(
Col Cumulative Sum( :height)));
