Hiding the Secondary Axis Labels JSL
emccall
New Contributor
Aug 28, 2017
Hi, was wondering if anybody knew any jsl code that hides seccondary axis labels. When I create a graph with elements in the seccondary axis, it creates a label on the right hand side that says, variable x and  2 more. For example, price and 2 more. I can manually click to hide this label, however, when I copy the script and re run it, the labels appear again. Does anybody know how to solve this? I am trying to mass produce graphs. Thanks
Jun 22, 2012
You can find all of the messages that you can pass to a platform in the Scripting Index
     Help==>Scripting Index
Here is an example taken from the Scripting Index that deletes the labels
Open( "$SAMPLE_DATA/Big Class.jmp" );
biv = Bivariate(
	Y( :weight ),
	X( :height ),
	FitLine
rbiv = biv << report;
axisbox = rbiv[axis box( 1 )];
axisbox << RemoveAxisLabel( "weight" );
emccall
New Contributor
Aug 28, 2017
Thanks! The scripting help is very useful. I have tried to use your code on my graph, but couldn't get rid of the title. My graph was created using graph builder. My title is "ask_lvl_1 & 7 more". It is located on the right side, going up and down (the seccondary axis). The 7 more represent 7 other variables on the axis. I have tried subsituting the variable names for 7 more and also using & to seperate the names. Any other suggestions?
emccall
New Contributor
Aug 28, 2017
I think I am just going to manually set the title to "" so no need to respond. Thanks!
