viskovicz00012
Help with Oneway with CDF
Help with the script. It does output the graph but the Quantiles, With Control,Box Plots, Means & Std Dev, CDF Plot, Mean Error Bars are not shown.
nwindow1 = New Window( "Control",<<Modal,
LineupBox
( (Ncol(2)),
Text Box( "Control Setup” ),control= Text Edit Box(),
Button Box( "OK",
               control = control << get text;
Button Box("Cancel", <<close window(no save));
If( nwindow1 == {Button( -1 )}, Stop() );
current data table(para_orient);
Fit Group(
        try(Oneway(
                Y( :Contact_1) ),
                X( :Orientation),
                With Control( 1, {char(control)} ),
                Quantiles( 1 ),
                Means and Std Dev( 1 ),
                CDF Plot( 1 ),
                Box Plots( 1 ),
                Mean Error Bars( 1 ),
                Std Dev Lines( 1 ),
                        Dispatch({},"Oneway Plot",FrameBox,
                        {DispatchSeg( Box Plot Seg( 1 ), Line Color( "Red" ) ),
                        DispatchSeg( Box Plot Seg( 2 ), Line Color( "Red" ) )}),
                        Dispatch( {}, "CDF Plot", OutlineBox, {SetHorizontal( 1 )} ))));,
        try(Oneway(
                Y( :Contact_2 ),
                X( : Orientation),
                Quantiles( 1 ),Means and Std Dev( 1 ),CDF Plot( 1 ),
                Box Plots( 1 ),Mean Error Bars( 1 ),Std Dev Lines( 1 ),
        try(Oneway(
                Y(:Contact_3),
                X( :Orientation),
                        Dispatch( {}, "CDF Plot", OutlineBox, {SetHorizontal( 1 )} )))),<<{Arrange in Rows(3)},
                        SendToReport( Dispatch( {}, "Fit Group", OutlineBox, {Set Title("Orientation="||char(ot_01)||"" )} )));
Re: Help with Oneway with CDF
I edited the script a little to match the parentheses and quotations.  Try this and see if it works for you.  The thing to remember is that you must enter a text that matches a level in "Orientation."  If you put in something that isn't included in the column, then none of the options in Oneway will be turned on.
LineupBox
( (Ncol()),
Text Box( "Control Setup" ),control= Text Edit Box(),
Button Box( "OK",
Button Box("Cancel");
Fit Group(
        try(Oneway(
                Y( :Contact_1 ),
                X( :Orientation),
                Quantiles( 1 ),
                CDF Plot( 1 ),
                Box Plots( 1 ),
                Std Dev Lines( 1 ),
        try(Oneway(
                Y( :Contact_2 ),
                X( : Orientation),
        try(Oneway(
                Y(:Contact_3),
                X( :Orientation),
                        SendToReport( Dispatch( {}, "Fit Group", OutlineBox, {Set Title("Orientation="||char(control)||"")} )));
LineupBox
( (Ncol()),
Button Box( "OK",
Fit Group(
        try(Oneway(
                Y( :Contact_1 ),
                X( :Orientation),
                Quantiles( 1 ),
                CDF Plot( 1 ),
                Box Plots( 1 ),
                Std Dev Lines( 1 ),
        try(Oneway(
                Y( :Contact_2 ),
                X( : Orientation),
        try(Oneway(
                Y(:Contact_3),
                X( :Orientation),
