gutloja
Help with Kernel Smoother output
[Kernel smoother - output in column]
Hello All,
I am running a kernel smoother but I would like to have the output of each smoother in a column, using the name of the variable. I still would like to see the Fit Group graph, for visual inspection, but I can't find a way to have JMP write the predicted values to a different column automatically [I usually save predicteds, coefficients, etc. manually].
Is there a way to do this?. This is the script I am using:
KernelSmootherGroup# = Expr(
Fit Group(
    Bivariate( Y( :Name( "Var1" ) ), X( :RowNO ),
        Kernel Smoother( 1, 1, 0.0985804416403786, 0 )
    Bivariate( Y( :Name( "Var2" ) ), X( :RowNO ),
    Bivariate( Y( :Name( "Var3" ) ), X( :RowNO ),
    <<{Arrange in Rows( 1 )},
        Dispatch(
            {"Bivariate Fit of Var1 By RowNO"},
            "2",
            ScaleBox,
            {Min( 0.1 ), Max( 1 ), Inc( 0.02 ), Minor Ticks( 1 )}
        Dispatch(
            "Bivar Plot",
            FrameBox,
            {Frame Size( 1085, 240 )}
        Dispatch(
            {"Bivariate Fit of Var2 By RowNO"},
            "2",
            ScaleBox,
        Dispatch(
            "Bivar Plot",
            FrameBox,
            {Frame Size( 1092, 240 )}
        Dispatch(
            {"Bivariate Fit of Var3 By RowNO"},
            "2",
            ScaleBox,
        Dispatch(
            "Bivar Plot",
            FrameBox,
            {Frame Size( 1096, 240 )}
KernelSmootherGroup#;
Any help will be appreciated,
JoseGL
Re: Help with Kernel Smoother output
Here is your script, modified with the code added that will output the Predicted values:
Names default to here(1);
dt=current data table();
       Fit Group(
              biv1=Bivariate( Y(:Name( "Var1" ) ), X( :RowNO ), Kernel Smoother(1, 1, 0.0985804416403786, 0 ) ),
              biv2=Bivariate( Y(:Name( "Var2" ) ), X( :RowNO ), Kernel Smoother(1, 1, 0.0985804416403786, 0 ) ),
              biv3=Bivariate( Y(:Name( "Var3" ) ), X( :RowNO ), Kernel Smoother(1, 1, 0.0985804416403786, 0 ) ),
                     Dispatch(
                           "2",
                           ScaleBox,
                     Dispatch(
"Bivariate Fit of Var1 By RowNO"}, "Bivar Plot", FrameBox, {Frame Size( 1085, 240 )} ),
                     Dispatch(
                           "2",
                          ScaleBox,
                     Dispatch(
"Bivariate Fit of Var2 By RowNO"}, "Bivar Plot", FrameBox, {Frame Size( 1092, 240 )} ),
                     Dispatch(
                           "2",
                           ScaleBox,
                     Dispatch(
"Bivariate Fit of Var3 By RowNO"}, "Bivar Plot", FrameBox, {Frame Size( 1096, 240 )} ),
biv1
<< (curve[1] << save predicteds);
biv2
biv3
       Fit Group(
                     Dispatch(
                           "2",
                           ScaleBox,
                     Dispatch(
                     Dispatch(
                           "2",
                          ScaleBox,
                     Dispatch(
                     Dispatch(
                           "2",
                           ScaleBox,
                     Dispatch(
biv1
biv2
biv3
gutloja
Thanks a lot, Jim.
This is what I was looking for.
