miketan
[Help] Data table side panel width JMP11
Is there anyway to set the default side panel width to a smaller value? When I open a new table the width is reasable but when I save the file as a .jmp and reopen the width suddenly jumps to 1/2 of the entire table and it is 99% empty space so I have to manually resize. I do not recall other JMP revisions doing this and am about to revert back to JMP10 because it is so inconvenient.
Re: [Help] Data table side panel width JMP11
The panel should open at the size it was saved at.   I have verified that with my 13.2 verison.  If you are getting different results, I would contact JMP
     support@jmp.com
