BookmarkSubscribeRSS Feed
rebecca-maceach
Mar 5, 2015
Hello, I can't seem to find the JSL code for adding a new column to a current data table that predicts values based on a cubic bivariate fit without a centered polynomial (from data in that table). I can only seem to do it for a linear fit. Also, Is it po
Hello, I can't seem to find the JSL code for adding a new column to a current data table that predicts values based on a cubic bivariate fit without a centered polynomial (from data in that table). I can only seem to do it for a linear fit. Also, Is it possible in JSL to not actually have the graph populate and to only save the predicted values from it? Thanks!
ms
Jun 23, 2011
Solution
Re: Hello, I can't seem to find the JSL code for adding a new column to a current data table that predicts values based on a cubic bivariate fit without a centered polynomial (from data in that table). I can only seem to do it for a linear fit. Also, Is i
Messages to a fitted curve should be part of a a list, and the Invisible option can be used to hide the report.
dt << Bivariate(
    Y( :weight ),
    X( :height ),
    Fit Special( Degree( 3 ), Centered Polynomial( 0 ), {Save Predicteds} ),
    invisible
ms
Jun 23, 2011
Solution
dt << Bivariate(
    Y( :weight ),
    X( :height ),
    invisible
