CanhKhong
Heatmap - statistics options
I found that heatmap set color from light to dark based on the count by default.
When I drag a continuous variable into the box "color" and it shows me the mean also by color. It's pretty cool!
If I want the heatmap shows me the sum or other statistics, do I have the option? If so, how I can do it and thanks.
Canh
hogi
Level XIII
Re: Heatmap - statistics options
You can right click on the color dropzone and go to Summary Statistics.
Sum is available  - like many other variants:
StarfruitBob
Hello @CanhKhong ,
After enabling a caption box in your graph, pointed to by the red arrow, you can use the options in the control panel to add more metrics.  For each statistic you want an additional "Summary Statistic" dropdown selection boxes will appear after you select a statistic in the dropdowns available.
Here's an example:
Names default to here(1);
dt = open( "SAMPLE_DATA/Big Class.jmp" );
dt << Graph Builder(
	Size( 559, 491 ),
	Fit to Window,
	Set α Level( 0.05 ),
	Variables( X( :height ), Y( :weight ), Overlay( :sex ) ),
	Elements(
		Heatmap( X, Y, Legend( 5 ) ),
		Caption Box(
			X,
			Y,
			Legend( 6 ),
			Summary Statistic( "Mean" ),
			Summary Statistic 2( "Median" )
Learning every day!
hogi
Level XIII
StarfruitBob
Hello @CanhKhong ,
Here's an example:
	Size( 559, 491 ),
	Fit to Window,
	Elements(
		Caption Box(
			X,
			Y,
			Legend( 6 ),
Learning every day!
CanhKhong
Thank you!
