lvminor
Heatmap appears in blocks instead of continuous
I am trying to make a heatmap to visualize some data.  However, when I utilize the heatmap in Graph Builder, my data appears in blocks instead of a nice continuous heatmap.  I used to be able to make continuous-looking heatmaps, but something changed.  What am I doing wrong?
Re: Heatmap appears in blocks instead of continuous
Is  the Modeling Type for your measurement data Ordinal or Nominal, instead of Continuous?
lvminor
Hi Jim, Nope I'm working with continuous data and have the appropriate blue triangle designation in JMP.
can you supply a sample of your data?
Which JMP version are you using?
Windows or Mac?
Could you have used a Contour element before, which will interpolate to fill the area?  It still uses discrete levels, but you can set the number of levels.
