vinkane
Having troulble with a dialog box script
Having troulble with a dialog box script to have the user select 1 or more selections, from a column of 100K rows. The column has no more then 6 different choices.
Thanks for the help
ian_jmp
Re: Having troulble with a dialog box script
Something like this, perhaps?
NamesDefaultToHere(1);
// Sample Character Data
dt = NewTable("Test Data", NewColumn("Column", Numeric, Nominal, Formula(RandomInteger(0, 10))), AddRows(10000));
dt << runFormulas;
Column(dt, "Column") << deleteFormula;
Column(dt, "Column") << dataType(Character);
// Dialog
distinctVals = AssociativeArray(Column(dt, "Column") << getValues) << getKeys;
nw = NewWindow("Select One or More Values",
lb = listBox(distinctVals, validateScript),
bb = ButtonBox("OK", OKscript, Enable(0))
// Validate script
validateScript =
Expr(
if(NItems(lb << getSelected) > 0, bb << Enable(1), bb << Enable(0));
// OK script
OKscript =
Expr(
nw << closeWindow; vals = lb << getSelected; Print(vals);
vinkane
Thanks....works well
Article Labels
