BookmarkSubscribe
maclines0
Community Member
Haplotype Regression
I am running the haplotype regression function and am unclear exactly how to interpret the output files. What I am most interested in is determining the trait mean for each haplotype. In the SAS output window I am given estimate values for each haplotype. These values are all negative for all haplotypes in the overall test while some are negative for some haplotypes and positive for others in the individual tests. Any help would be appreciated. I attached the output below:
                                                            Overall Test                         16:33 Monday, February 29, 2016  20
------------------------------------------------------------- Window=1 -------------------------------------------------------------
                                                         The GLM Procedure
                                              Number of Observations Read         132
                                              Number of Observations Used         132
                                                            Overall Test                         16:33 Monday, February 29, 2016  21
                                                         The GLM Procedure
                                                  Dependent Variable: PSS_2013
        Sum of
                        Source                      DF         Squares     Mean Square    F Value    Pr > F
                        Model                        7      0.57061574      0.08151653       5.13    <.0001
                        Error                      124      1.97091759      0.01589450
                        Corrected Total            131      2.54153333
                                       R-Square     Coeff Var      Root MSE    PSS_2013 Mean
                                       0.224516      59.09690      0.126073         0.213333
                        Source                      DF       Type I SS     Mean Square    F Value    Pr > F
                        H1                           1      0.04265381      0.04265381       2.68    0.1039
                        H2                           1      0.01099720      0.01099720       0.69    0.4071
                        H3                           1      0.15427488      0.15427488       9.71    0.0023
                        H4                           1      0.15181720      0.15181720       9.55    0.0025
                        H5                           1      0.13429041      0.13429041       8.45    0.0043
                        H6                           1      0.07494326      0.07494326       4.72    0.0318
                        H7                           1      0.00163899      0.00163899       0.10    0.7487
                        Source                      DF     Type III SS     Mean Square    F Value    Pr > F
                        H1                           1      0.00756075      0.00756075       0.48    0.4917
                        H2                           1      0.03763456      0.03763456       2.37    0.1264
                        H3                           1      0.29761793      0.29761793      18.72    <.0001
                        H4                           1      0.24398325      0.24398325      15.35    0.0001
                        H5                           1      0.17124082      0.17124082      10.77    0.0013
                        H6                           1      0.07487811      0.07487811       4.71    0.0319
                        Contrast                    DF     Contrast SS     Mean Square    F Value    Pr > F
                        Overall                      7      0.57061574      0.08151653       5.13    <.0001
        Standard
                                 Parameter         Estimate           Error    t Value    Pr > |t|
                                 Intercept     0.2890451760      0.02424577      11.92      <.0001
                                 H1            -.0302601288      0.04387445      -0.69      0.4917
                                 H2            -.0674181711      0.04381340      -1.54      0.1264
                                 H3            -.1993103565      0.04605998      -4.33      <.0001
                                 H4            -.2019650826      0.05154893      -3.92      0.0001
                                 H5            -.1608493234      0.04900484      -3.28      0.0013
                                 H6            -.1115559265      0.05139710      -2.17      0.0319
                                                            Overall Test                         16:33 Monday, February 29, 2016  22
                                                         The GLM Procedure
        Standard
                                 H7            -.0151106871      0.04705650      -0.32      0.7487
                                                        Test for Haplotype 1                     16:33 Monday, February 29, 2016  23
                                                         The GLM Procedure
                                                        Test for Haplotype 1                     16:33 Monday, February 29, 2016  24
                                                         The GLM Procedure
        Sum of
                        Model                        1      0.04265381      0.04265381       2.22    0.1387
                        Error                      130      2.49887952      0.01922215
                                       0.016783      64.98936      0.138644         0.213333
                        H1                           1      0.04265381      0.04265381       2.22    0.1387
        Standard
                                 Intercept     0.2058495133      0.01307144      15.75      <.0001
                                 H1            0.0604036959      0.04054951       1.49      0.1387
                                                        Test for Haplotype 2                     16:33 Monday, February 29, 2016  25
                                                         The GLM Procedure
                                                        Test for Haplotype 2                     16:33 Monday, February 29, 2016  26
                                                         The GLM Procedure
        Sum of
                        Model                        1      0.00464098      0.00464098       0.24    0.6266
                        Error                      130      2.53689236      0.01951456
                                       0.001826      65.48180      0.139695         0.213333
                        H2                           1      0.00464098      0.00464098       0.24    0.6266
        Standard
                                 Intercept     0.2108940059      0.01314754      16.04      <.0001
                                 H2            0.0199012940      0.04080901       0.49      0.6266
                                                        Test for Haplotype 3                     16:33 Monday, February 29, 2016  27
                                                         The GLM Procedure
                                                        Test for Haplotype 3                     16:33 Monday, February 29, 2016  28
                                                         The GLM Procedure
        Sum of
                        Model                        1      0.18816586      0.18816586      10.39    0.0016
                        Error                      130      2.35336747      0.01810283
                                       0.074036      63.06879      0.134547         0.213333
                        H3                           1      0.18816586      0.18816586      10.39    0.0016
        Standard
                                 Intercept     0.2281706052      0.01258261      18.13      <.0001
                                 H3            -.1357147781      0.04209494      -3.22      0.0016
                                                        Test for Haplotype 4                     16:33 Monday, February 29, 2016  29
                                                         The GLM Procedure
                                                        Test for Haplotype 4                     16:33 Monday, February 29, 2016  30
                                                         The GLM Procedure
        Sum of
                        Model                        1      0.12443421      0.12443421       6.69    0.0108
                        Error                      130      2.41709913      0.01859307
                                       0.048960      63.91707      0.136356         0.213333
                        H4                           1      0.12443421      0.12443421       6.69    0.0108
        Standard
                                 Intercept     0.2242132838      0.01259143      17.81      <.0001
                                 H4            -.1263698272      0.04884826      -2.59      0.0108
                                                        Test for Haplotype 5                     16:33 Monday, February 29, 2016  31
                                                         The GLM Procedure
                                                        Test for Haplotype 5                     16:33 Monday, February 29, 2016  32
                                                         The GLM Procedure
        Sum of
                        Model                        1      0.06560886      0.06560886       3.44    0.0657
                        Error                      130      2.47592448      0.01904557
                                       0.025815      64.69017      0.138006         0.213333
                        H5                           1      0.06560886      0.06560886       3.44    0.0657
        Standard
                                 Intercept     0.2208798843      0.01268136      17.42      <.0001
                                 H5            -.0873881772      0.04708347      -1.86      0.0657
                                                        Test for Haplotype 6                     16:33 Monday, February 29, 2016  33
                                                         The GLM Procedure
                                                        Test for Haplotype 6                     16:33 Monday, February 29, 2016  34
                                                         The GLM Procedure
        Sum of
                        Model                        1      0.00496349      0.00496349       0.25    0.6149
                        Error                      130      2.53656985      0.01951208
                                       0.001953      65.47764      0.139686         0.213333
                        H6                           1      0.00496349      0.00496349       0.25    0.6149
        Standard
                                 Intercept     0.2154476441      0.01286049      16.75      <.0001
                                 H6            -.0252461592      0.05005571      -0.50      0.6149
                                                        Test for Haplotype 7                     16:33 Monday, February 29, 2016  35
                                                         The GLM Procedure
                                                        Test for Haplotype 7                     16:33 Monday, February 29, 2016  36
                                                         The GLM Procedure
        Sum of
                        Model                        1      0.04871084      0.04871084       2.54    0.1134
                        Error                      130      2.49282249      0.01917556
                                       0.019166      64.91055      0.138476         0.213333
                        H7                           1      0.04871084      0.04871084       2.54    0.1134
        Standard
                                 Intercept     0.2071830763      0.01265543      16.37      <.0001
                                 H7            0.0721643793      0.04527767       1.59      0.1134
                                                        Test for Haplotype 8                     16:33 Monday, February 29, 2016  37
                                                         The GLM Procedure
                                                        Test for Haplotype 8                     16:33 Monday, February 29, 2016  38
                                                         The GLM Procedure
        Sum of
                        Model                        1      0.52691021      0.52691021      34.00    <.0001
                        Error                      130      2.01462312      0.01549710
                                       0.207320      58.35345      0.124487         0.213333
                        H8                           1      0.52691021      0.52691021      34.00    <.0001
        Standard
                                 Intercept     0.1932524844      0.01136935      17.00      <.0001
                                 H8            0.2484527632      0.04260894       5.83      <.0001
sbrlsi
Re: Haplotype Regression
If I understood your question correctly, you want the Least Square Means (LS Means) of each haplotype. Since you have results from the Overall Test and Individual Test, you can get two LS Means estimates for each haplotype. In either case, the LS Means for the haplotype is the sum of the Intercept and the haplotype estimate. The LS Means from the Overall Test is conditional on other haplotypes fitted together in the model and it may change if you change the model (say, remove haplotypes from the model), while the LS Means from the Individual Test is unconditional to other haplotypes because the model has only one haplotype.
LS Means H1 (overall test) = 0.2890451760 + (-.0302601288) = 0.2587850472
LS Means H1 (individual test) = 0.2058495133 + 0.0604036959 = 0.2662532092
Sincerely yours,
Luciano Silva
Thanks for posting this question.
First, if you are looking for the mean for your trait (PSS_2013) for each haplotype, then take a look at each section labelled Test for Haplotype Hx where x is the Haplotype number. Within each section there is an item called PSS_2013 Mean. That would be the mean for the trait for that haplotype. Is that what you are looking for? These individual sections for each haplotype are the individual tests for each haplotype as opposed to the whole model fit where all haplotypes are fit together (at the beginning) and the PSS_2013 Mean is the mean for the whole fit, instead of the individual fits.
The Parameter Estimates are the slope of the fit for each haplotype as individual tests or the whole model fit and represent the effect (+ is a positive effect and - is a negative effect) on that trait for each haplotype or when fit together, their effect when considering the other haplotypes.
Does that help explain the output?
Best,
Chris Kirchberg
Chris Kirchberg
Principal Systems Engineer, Life Sciences - JMP Global Technical Enablement
SAS Institute, Inc. - Denver, CO
Tel: +1-919-531-9927 ▪ Mobile: +1-303-378-7419 ▪ E-mail: chris.kirchberg@jmp.com
JMP – A Division of SAS Institute | www.jmp.com
sbrlsi
Sincerely yours,
Luciano Silva
sbrlsi
I must correct myself when I said LS Means in the previous reply; instead, the values I defined as LS Means are indeed the predicted means for each haplotype.
My apologies.
Luciano Silva
