scottpenner
Grouping measurement runs of different duration
I have a column of data and a time stamp for a test performed over several minutes.  The test consists of multiple bursts of data over this time period.  I need to analyze each burst of data and compare statistics between bursts.
The problem is that the data has an irregular number of points.  Each burst is separated by a few seconds, so I can use the time stamp to group the data.  However, I haven't figured out how to make that work.
I can use the DIF function to figure out the transitions between groups, but I do not know how to increment a group number at this transition.
The goal would be to have a group number for each burst of data.  Any ideas?  I'm pretty handy with formula's but haven't done any scripting yet.
Thanks,
Scott
ms
Super User ms
Re: Grouping measurement runs of different duration
Try the column formula below. It should give each burst a number from 1 to 10 (if the table is sorted correctly).
If( Row() == 1,
  1,
  If( Dif( :Name( "Time (111447_138)" ), 1 ) > 1,
  Lag( :Column 4, 1 ) + 1,
  Lag( :Column 4, 1 )
ms
Super User ms
If( Row() == 1,
  1,
  Lag( :Column 4, 1 )
scottpenner
Thanks.  That worked great.
I'd never used the Lag function before.  Perfect.
