BookmarkSubscribe
pmroz
Grid Control in JMP Dialog Boxes?
Hi folks,
Has anyone figured out how to do some sort of grid control in JMP dialog boxes?  Something similar to SCgrid in VB?  I want to display a scrollable table with clickable controls in it.
Thanks,
Peter
ms
Super User ms
Re: Grid Control in JMP Dialog Boxes?
Just action_list[1] works but not the entire list. Thus, Col Box() seems unable to resolve a List of display boxes which usually means that one has to make and parse an enormous expression string.
dt = open("$sample_data\Car Physical Data.jmp");
current data table(dt);
model_list   = :Model << get values;
Country_list = :Country << get values;
type_list    = :Type << get values;
weight_list  = :Weight << get values;
turn_list    = :Turning Circle << get values;
disp_list    = :Displacement << get values;
horse_list   = :Horsepower << get values;
gas_list     = :Gas Tank Size << get values;
bb_text="button box(\!"Open\!", print(1))";;
for (i = 2, i <= nrows(dt), i++,
      bb_text = bb_text||", "||char(substitute(nameexpr(button box("Open", print(expr(i)))),expr(i),i));
col_box="col box(\!"Action\!", "||bb_text||")" ;
New Window( "Cars",
      tb = Table Box(
                 eval(parse(col_box)),
                  String Col Box("Model", model_list),
                  String Col Box("Country", country_list),
                  String Col Box("Type", type_list),
                  Number Col Box("Weight", weight_list ),
                  Plot Col Box( "", weight_list),
                  Number Col Box("Turning Circle", turn_list ),
                  Number Col Box("Displacement", disp_list ),
                  Number Col Box("Horsepower", horse_list ),
                  Number Col Box("Gas Tank Size", gas_list ),
                  Plot Col Box( "", gas_list),
tb << Set Scrollable( 25, 0 );
tb << table style(beveled);
7 REPLIES 7
XanGregg
In JMP 10, Table Box has a Set Scrollable message and Col Box which is a display table column where each row is a different display box of your choosing.
Another option, which I haven't tried, is putting a Lineup Box inside a Scroll Box.
pmroz
Almost there.  Didn't know about col box, which is not documented anywhere except for a brief mention in Help > Scripting Index.  Maybe someone can help me get this example to work:
action_list = {};
for (i = 1, i <= nrows(dt), i++,
      bb_text = "action_list = button box(\!"Open\!", print(i))";
      eval(parse(bb_text));
New Window( "Cars",
      tb = Table Box(
                  col box("Action", action_list),
ms
Super User ms
New Window( "Cars",
      tb = Table Box(
Col Box is similar to Outline Box in it's arguments.  You could build up the list similar to the way Peter did:
action_col = col box("Action");
      bb_text = "action_col << append(button box(\!"Open\!", print(i)))";
Now you have the column that you can add to the table.
pmroz
Thanks so much MS!  I took your code and changed it slightly so that each button is the "Go" icon:
action_list = {};
bb_text = "";
    bc = "b" || char(i);
    bb_text = bb_text || bc || " = button box(\!"\!", print(\!"" || bc || "\!"); ), ";
col_box_expr = "col box(\!"Action\!"," || bb_text || " )";
New Window( "Cars",
    tb = Table Box(
            eval(parse(col_box_expr)),
    button_expr = bc || " << set icon(\!"Go\!")";
    eval(parse(button_expr));
Very cool result.  Clicking on a button shows which button was pressed.
gatovolador
Community Member
Here is an alternative approach, using a LineupBox filled with BorderBoxes, MouseBoxes, and TextBoxes that acts like a table.  The MouseBox can provide the clickable controls and the BorderBox can provide the ability to colorize the table cells.
KinKame
cool !!!
